DC Linkert Idle Tube
  • billpedalino
    • Mar 2005
    • 1096
    I've been looking for an idle tube for my Linkert DC-12 through friends, Ebay, etc.without success. I haven't found a used OEM tube and it doesn't appear that they're being re-manufactured. From what I can tell, it appears that these tubes are the same for all Sportsters and for 1966 shovelheads. If anyone has one that they'd be willing to sell, I'm certainly interested. If so, please email me directly at WPedalino@Caldwell;Marnine.com.
    Thank You...
    Bill Pedalino
    Huntington, New York
    AMCA 6755
  • silver65
    • Nov 2020
    • 176
    Have you tried " parts@linkertcarbs.com "
    • ammorest
      • Sep 2008
      • 295
      Bill, is it 27323-57?
      Dave
      • billpedalino
        • Mar 2005
        • 1096
        Yes Dave - that's the one...
        Bill Pedalino
        AMCA 6755
        • billpedalino
          • Mar 2005
          • 1096
          Yes - he's doesn't have one.
          Bill Pedalino
          AMCA 6755
          • billpedalino
            • Mar 2005
            • 1096
            Yes Dave - That's the one.
            Bill Pedalino
            AMCA 6755
            • billpedalino
              • Mar 2005
              • 1096
              Yes - I tried the Linkert guy. He doesn't have any.
              Bill Pedalino
              AMCA 6755
              • wz507
                • Oct 2016
                • 8
                Says it’s a Bendix part, but may be correct for your Linkert.
                https://www.ebay.com/sch/i.html?_fro...23-57&_sacat=0
                Available in Europe
                • ammorest
                  • Sep 2008
                  • 295
                  Bill, PM me your address; I have misplaced your card.
                  Dave
                    • 8229
                    It doesn't look right, Wz507,..
                    (DC on far right in pic.)
                    Late edit: Doh, that's the nozzle. Sorry.
                    It appears to be a simple brass tube, Bill!
                    Unfortunately, I have none currently on the bench to copy, but plenty of 3/16" tubing if you need any.
                    • billpedalino
                      • Mar 2005
                      • 1096
                      Cotten,
                      Thanks for looking. Yes, it's a simple tube, but it has a swaged sleeve on the bottom that I would have a hard time duplicating.
                      Bill Pedalino
                      AMCA 6755
                      • billpedalino
                        • Mar 2005
                        • 1096
                        Also, there's a small inlet hole (about 0.027" Dia.) drilled through one side of the tube just above the pressed-on sleeve. The sleeve is closed on one side thus acting as s stop so that the fuel only enters through the side hole and drawn up.
                        Bill Pedalino
                        AMCA 6755
                          • 8229
                          Got a pic, Bill?
                          (Next to a ruler would help..)
                          It sounds simple; Can you draw one?
                          • billpedalino
                            • Mar 2005
                            • 1096
                            Please see the attached sketch - I hope it's inserted (not the most user-friendly system).
                            The measurements shown are as close as I could get using a mechanical Caliper.
                            Bill Pedalino
                            AMCA 6755
                              • 8229
                              3/32" brass tubing is available, Bill!
                              But I don't know if any is 1mm bore.
                              .....Cotten
