'71 Sporster Tires
  • drhank
    '71 Sporster Tires
    Does anyone have an idea as to the widest tire I can put on my 16 inch rear rim ??? How about the 19 in front ??? Don't worry about the frame or fork width.
  • rousseau
    It depends on how wide your rim is. Almost all 16 inch rims were 3 inches wide. If so, I wouldn't go wider than 150-80.
    • VPH-D
      The stock front rim mounted a 375 19 tire. The biggest 16 we used to get away with was 5.10 16. Any larger and the side wall would be cut by fender support strut bolts.
      VPH-D
      • drhank
        Thanks for the replys. I have a wider hardtail frame so I was wondering how wide you can get without having the sidewalls roll over the rims. Or doesn't that happen ?
