Spark Plugz
  • brettxlch
    • Jan 2019
    • 141
    Spark Plugz
    Guys do you know what the orig brand of plug and part number came in my 73 XLCH ? Just Curious...thanx
    • 5950
    Originals were Harley-Davidson brand. Actually made by Champion. The main difference on H-D plugs is that there is no pre gap inside the porcelain. Back in the dasy I would use Champion J 12. I don't believe these are available today.
    • brettxlch
      • Jan 2019
      • 141
      Thanx Chris, thats very interesting, maybe one of the club members have some pix. Gee had no idea harley did this.....but im fairly new to the hobby..brett
      • pan620
        • Oct 2016
        • 223
        H-D 4-5, i believe that is what they came with.
        • kitabel
          • Sep 2018
          • 471
          4-5 is the heat range (not the plug type) and is used for all models regardless of plug type.
          The iron Sportster used the Champion 14mm thread, letter code "H" plug with 7/16" reach (depth in the head).
          The Champion "J" code is 14mm × 3/8" reach, it fits the Sportster but it's too short and carbon will form on the unused exposed threads inside the head. It was used in panhead engines.
          I have some more comments on my site here: http://victorylibrary.com/tech/plug.htm
          The Linkert Book
            • 4783
            The old Champion crossover was an H-10 for Sportster, the equivalent of an old H-D #4.
              • 2030
              H8C or H10C Champion in todays numbers
              • ihrescue
                Super Moderator
                • Jun 2015
                • 1141
                Just to add a little more detail from the MoCo side of things the Harley Davidson XLH, XLCH Parts Catalog offers all the following part numbers for both XLCH and XLH for 1971 - 1978. Indications are that they are exchangeable to XLH and XLCH for those years and no explanation on what is the difference between the plugs associated with the part numbers.
                Spark Plug No. 2 ( 2) 71 to 78 - XLH, XLCH 32305-48A
                Spark Plug No. 3 (2) 71* - XLH, XLCH 32303-47A
                Spark Plug No. 4 (2) 71* - XLH, XLCH 32301-47A
                Spark Plug No. 4R (2) 71* - XLH, XLCH 31629-78 (radio static suppression)
                Spark Plug No. 5 (2) 71* - XLH, XLCH 32307-58
                Not sure if this is useful if you already have the Champion number.
                Mike Love
                Last edited by ihrescue; 03-19-2019, 07:50 AM. Reason: Champion, XLH, XLCH, Spark Plug, Radio Static Suppression
                  • 2030
                  The R plug is resistor for radio or electronic ignition
                  the others are heat range
                  • TomL
                    • Jan 2018
                    • 109
                    H8C/HD 4 32301-47a 14mm tpi/.440" reach(11.2mm) 1972-1978 Sportster 1000cc
