try again Transmission MAINSHAFT thrust washer
  • scottie
    • Apr 2018
    • 5
    Is pin P/N 600 for transmission MAINSHAFT thrust washer needed?
  • pan620
    • Oct 2016
    • 223
    What year are you working on?
    • scottie
      • Apr 2018
      • 5
      1966 xlch..got the bike apart for crank rebuild and noticed the pin for trans thrust wash not in case..after inspection of washer ect. all is good no metal transfer no burn and checks on mic...was wondering if pin is needed..I did order pin and going to install but I was interested in others thoughts on this
      • pan620
        • Oct 2016
        • 223
        My thoughts are it keeps the thrust washer from turning....if all looks fine I guess it most have been happy without it, but I would put it back in.
        • scottie
          • Apr 2018
          • 5
          Agreed..thanks for input
