1969 XLH Fork Oil Dumb Question
  • jupiter2
    • Nov 2008
    • 44
    Hello,
    I'm finishing up my first Sportster, a 1969 XLH and I have a question about adding fork oil that I am hoping someone can answer,
    The service manual describes the construction of a very complicated filler can, which seems to be for adding the oils while making sure all the air is out.
    So my dumb question is - is this necessary? Or, is there a simpler way to add the 4-1/2 ounces called out in the manual?
    Jim
    AMCA #466
    You don't have to filter anything. Short of pulling the tubes out your stuck tin can. The thing in the book works pretty good. I just soldered a tin can to a metal funnel. The other end is just a rubber stopper with a piece of copper tubing though it. It take for ever and a day for the fluid to drip though the breather valve. This is were the tin can comes in. If ya make a handle for it, you get to hang it up and drink a beer while you watch you tin can. In fact after four or five beers you can start having one hell of a relationship with your tin can. Bob L
      • 4783
      That describes a filler for a Big Twin. On your 69 Sportster all you need to do is put a block under the frame and remove one cap at a time (if you remove both the forks will collapse completely), then dump the oil in. They do not have a restricted double cap like a BT.
      • jupiter2
        • Nov 2008
        • 44
        One yay, one nay.
        I think I need a tie-breaker on this one!
        Can we get a confirmation?
        Jim
        AMCA #466
          • 4783
          OK, I'm done....
          • jupiter2
            • Nov 2008
            • 44
            Sorry, Rubone. Not sure what you mean.
            I'll try your recommendation.
            There were two contradicting replies, so I wasn't sure of which was correct.
            Jim
            AMCA #466
              Robbie right, I forgot that the taper of the tube on a Sportster comes straight into the top triple tree. Like he said one at a time.
