69-70 Bronson style mufflers
  • otis71
    • Jul 2015
    • 593
    I recently bought a set of 69-70 stacked mufflers. The parts book lists them as separate part numbers-65227-68 lower and 65228-68 upper. Both mufflers are identical with just 1 mounting loop on the top which fits up to the support bracket. It seems the upper should have a bracket on the bottom to suspend the lower. Is this correct? I’m thinking I have 2 lowers. Any help is appreciated.
  • Sportster Jerry
    • Jul 2007
    • 165
    The top muffler should have indents to clear the bottom of the rear shock.
    The lower muffler has no indents.
    • billpedalino
      • Mar 2005
      • 1096
      I'm looking for a similar exhaust system for my 1970 XLCH. If anyone has one for sale, please reply.
      Thanks...
      Bill Pedalino
      Huntington, New York
      AMCA 6755
      • 59xlh
        • Apr 2018
        • 24
        Have a pair of mufflers and the mounting bracket. Light road rash and the chrome is thin. No extra dents. Located in Connecticut.
        • chuckthebeatertruck
          • Jun 2018
          • 684
          Thanks...
          I know for sure Kirk Kelly at sporty parts has the rear pipe -- he just posted in another forum about having it for sale. Reading between the lines on some other conversations with him, it sounded like he had at least one good used set minus the lower support bracket.
          I know I saw at least two complete systems at Wauseon and one at Davenport. Attached is a pick of the Davenport system -- it was on the ground next to or under the table with the linkerts on it (I can't remember which). I hope some one will be able to id the vendor for you from the picture.
          • billpedalino
            • Mar 2005
            • 1096
            Thank you for responding.
            How bad is the road rash? Is it repairable? If so I mat be interested...
            Bill Pedalino
            AMCA 6755
            • billpedalino
              • Mar 2005
              • 1096
              [ATTACH=CONFIG]26243[/ATTACH]
              [ATTACH=CONFIG]26244[/ATTACH]
              Thanks for responding....
              That's great information. I would first like to see what 59xlh has and if it's too badly damaged for my repair skills I may reach out Mr. Kelly. Do you have is contact information?
              Bill Pedalino
              AMCA 6755
                • Jun 2018
                • 684
                The finest parts & accessories for Harley Davidson Sportsters & K-Models. Servicing Southern California and shipping internationally since 1993.
                Local: 714-879-0500
                Toll Free: 800-701-2925
                Good luck. They've suddenly become popular systems :-)
                • 59xlh
                  • Apr 2018
                  • 24
                  Bill, I'll try to get some pic's up tomorrow. Thanks, Tom.
                  • 59xlh
                    • Apr 2018
                    • 24
                    I'm not the best photographer. Also have NOS rear pipe.P1010011.jpgP1010004.jpg
                    • 59xlh
                      • Apr 2018
                      • 24
                      P1010014.jpgP1010015.jpg Couple of small dents no back side not visible.
                      • 59xlh
                        • Apr 2018
                        • 24
                        • billpedalino
                          • Mar 2005
                          • 1096
                          I'm not the best photographer. Also have NOS rear pipe.[ATTACH=CONFIG]26259[/ATTACH][ATTACH=CONFIG]26260[/ATTACH]
                          Thanks 59xlh, ,but I think I'll continue looking. I probably could repair the road rash with a layer of brass, as its fairly deep but it's a lot of work.
                          Thanks for responding!
                          Bill Pedalino
                          AMCA 6755
                            • 8230
                            ... I probably could repair the road rash with a layer of brass, as its fairly deep but it's a lot of work....
                            Low temp silver-solder, Bill!
                            Brass requires heat that makes the steel brittle.
                            PS: It polishes out a whole lot better, too.
                            • billpedalino
                              • Mar 2005
                              • 1096
                              Cotten,
                              You're correct about the brazing causing brittleness in sheet metal. How does the silver-colder react to chrome plating?
                              Bill Pedalino
                              AMCA 6755
