Tapered bead tires
  • otis71
    • Jul 2015
    • 597
    Tapered bead tires
    I have tapered bead Goodyear front and rear tires as found on 1971 and up (I believe) XL models. Will these tires work safely on 64-70 style non tapered Borrani rims? If anything I would think they would be tight because conventional tires are loose on tapered rims. Finding the correct tires is next to impossible.
