Morris Mag Advance/Retard Cap
  • 63panryder
    • Nov 2013
    • 2
    I just finished a 59 XLCH project. Runs like a champ when I can get it started.
    Has anyone used that mag cap from Morris Magnetos with the lever that can retard
    the spark on a fixed mag.
  • larry
    • May 2009
    • 247
    Yes. It works. Can be had with whatever color cap they stock.
    • Zaemo
      • Dec 2014
      • 52
      I had a hard time with that setup.
      • slamiste
        • Mar 2010
        • 260
        Hi,
        I'm using that setup on an Indian Power Plus. The advance / retard feature works well. It's been a while since I looked at the internals but I think the mag itself needs to be modified for use with this setup. I don't think you can simply change out the cap and have everything work correctly. Again, I not sure about this but if you contact Morris I'm sure they can clarify what needs to be done. They've been very helpful with me in the past.
        Steve Slaminko
        • Shaky Jake
          Ol' Poop
          • Jan 2013
          • 261
          Originally posted by slamiste View Post
          Hi,
          Steve Slaminko
          Hey Steve, by any chance can I see a picture of how you connected the Powerplus linkage to the Morris spark advance?
          Kevin
          Kevin
          • slamiste
            • Mar 2010
            • 260
            Happy New Year Kevin,
            I haven't connected the advance / retard lever on the Morris mag to the handlebar linkage yet. I was in a hurry to get the bike running for a local event and since the hookup was going to require some engineering and manufacturing I started the bike with the spark retarded the ran full advance while on the highway to the event. That worked out well enough that I continued that procedure for the rest of the season. I hope to get it hooked up properly this winter if I can get to it. I'll send you pictures when and if it's done.
            I don't remember if I've congratulated you on your Cannonball run. In any case I enjoyed talking to you in Indiana and have enjoyed watching the videos you've posted. Well Done!!! I can't imagine riding a PowerPlus 100 miles let alone over 3000.
            • Shaky Jake
              Ol' Poop
              • Jan 2013
              • 261
              Thanks Steve. I figured I'd do it the same way if I ever had to use the Morris mag that I had along as a spare.
              Kevin
              Kevin
