Sportster trap door aligment
  • Steve Little
    • Apr 2008
    • 915
    I will start with a clarification:
    This 1968 xlch engine will not end up in a restored bike, but is being modified into a race engine to race in Period 3 Classic series.
    I bought the bare cases knowing that they had some issues but......
    The eBay seller's description of “a couple of small issues” has turned out to be a large understatement and he could consider cutting back on the crack pipe.
    One of the smaller issues of the right case was the counter shaft bearing area being flogged out and beyond a bearing fit. I've welded this spigot in readiness for boring, but there is a lot more welding to be done to strengthen this area before I can think about boring the hole.
    At this stage, some of you may scratching your head and wondering how a race engine has any place on a restoration forum.
    I wanted to check if I had put enough weld in the repaired spigot before boring it.
    The closed end bearing is an interference fit in the case.
    I put three parallel bars on the mill table and snugged the cases down to it.
    I needed to find the center of the welded spigot, and my plan was to use the trap door that I intended to use on the engine.
    I decided to use the known areas of the case as zero “main shaft bearing” of the right case to check if the trap door lined up.
    This is where I got side tracked from my original mission.
    I put a dial indicator on the quill and lowered it into the main shaft bearing race, and zeroed the table readouts. I torqued the “performance” trapdoor into place and then put the dial indicator on the clutch gear.
    The following table movements were required to center the shaft of the trap door; X. - 0:195” Y. - 0:165”.
    There is no way a bearing is going to put up with this type of shenanigans.
    I then decided to use an original trap door and do the same procedure:
    X. - 0.050” Y. - 0.070”
    This measurement is still beyond any sort of acceptable tolerance.
    My point: Sportster owners piecing together an engine... beware of miss matched/miss aligned parts.
    Regards Steve
    Steve Little
    Upper Yarra Valley. Victoria.
    Australia.
    AMCA member 1950
  • motorhead1
    • Dec 2006
    • 171
    Are the case halves a matched factory set? I have seen this problem with non-paired case halves before. The trolls are out there.
    Ride 'em. Don't hide 'em.
    Dan #6938 FUBO
    • Steve Little
      • Apr 2008
      • 915
      Hi Dan.
      Thanks for your input.
      I haven't played with Sportster engines much.
      I thought I would hilite this trap door issue to inform other builders.
      Is this trapdoor misalignment a common problem with Sportsters?
      I can imagine that mis-matched case sets would have a few areas to be checked, but these are a matched set.
      Regards Steve
      Steve Little
      Australia.
      AMCA member 1950
      • Steve Little
        • Apr 2008
        • 915
        I know everybody loves to see engine numbers so, here they are.
        Steve Little
        Australia.
        AMCA member 1950
        • motorhead1
          • Dec 2006
          • 171
          Hello again Steve. I've been thinking about your case issue. Have you tried checking the X/Y with the main shaft race removed? Even if the race is new, it's centerline could be off. As far as the Trock door, it definitely has a problem and they were overkill anyway. We ran the stock doors in the AHDRA "B" class for years without a breakage. Hope you get it sorted out.
          Dan #6938 FUBO
          • Steve Little
            • Apr 2008
            • 915
            Robbie posted on another thread that left hand replacement case halves came supplied with a trap door. I'm a believer, and I know everyone likes pictures:
            [IMG] photo NOS Sporty case and trap door_zpsg4mdtdpq.jpg[/IMG]
            Or here is the link to the ebay item.
            Steve Little
            Australia.
            AMCA member 1950
