69 xlh motor question
  • 46CHF
    • Nov 2009
    • 68
    I am currently rebuilding a 69 xlh motor . This is my first xlh and not familiar with oil line connections. What is the port at 7 o'clock to the rear exhaust cam and what type fitting does it take
    • 5947
    Pictures?...
    • murph
      1959 xlch
      • Jun 2009
      • 226
      This is a 69 ch motor, the feed and return are the same as the H. Not sure which one your looking for but the left is the feed the right is the return. Check your parts book on the fittings I think they are the same as what you see here, but I'm not an H man.
      1959 XLCH
      • 46CHF
        • Nov 2009
        • 68
        The cases I have the port is at the lower left 7 o'clock to the rear exhaust cam and is threaded at an angle 1/8 npt
        • murph
          1959 xlch
          • Jun 2009
          • 226
          Pictures are everything, post some so we know exactly what your talking about. I'm not sure what your getting at.
          1959 XLCH
          • vph-d
            • 1082
            Are any of the oil lines as small as 1/8" ?
            VPH-D
            • 46CHF
              • Nov 2009
              • 68
              I will take a few pics and post soon
                • 4775
                Only the feed to the top end.
                • 46CHF
                  • Nov 2009
                  • 68
                  Pictures of oil fittings go
                  Picture of oil port location not sure what the one at 7 o'clock to the rear cam and what is the proper fitting for there. also the breather is slightly off the mark when timing marks are lined up
                  • painterdale
                    • Oct 2013
                    • 423
                    For what it's worth- my '67 XLH has an 1/8th pipe plug in it, but it is nowhere near a stock bike. Dale
                    • 46CHF
                      • Nov 2009
                      • 68
                      Just trying to figure out what type fitting or plug was used here or were it connectedimage.jpg
                        • 4775
                        Used where??
                        • vph-d
                          • 1082
                          I think that threaded hole is for the chain oiler supply line.
                          VPH-D
                          • 46CHF
                            • Nov 2009
                            • 68
                            Thanks for the reply Robbie , this is Artie Frank by the way. I am trying to figure out what the port is to the left rear of the rear exhaust cam I put the oil line fitting in but not sure if that is correct .also if you would look at the location of breather timing. The timing mark is in center of inspection hole gears are all in alignment but breather seems to be a little regarded about half of the hole in breather. See picture
                              • 4775
                              Hi Artie,
                              How you doing?
                              Make sure the pinion gear is spaced out the proper distance from the gasket surface in order to check the breather timing. The distance is critical.
                              The oil fitting looks like this.
