XLCH Front Fender
  • billpedalino
    • Mar 2005
    • 1096
    XLCH Front Fender
    I have installed the front fork legs on my '64 and started fitting up the front fender. While I'll admit that I haven't taken the time yet to fully analyze the problem, it looks like the fender doesn't fit. While it may just be a simple case of bowed fender braces, I thought that I'd gather some information before I start obsessing with a bending bar. I do have an OEM fender and OEM lower legs.
    WHAT I KNOW:
    From what I can tell, the front fender that I have is P/N 59007-52C and fits the 1959 - 1969 XLCH. The 1970 fender, P/N 59007-70 has a totally different mounting set-up.
    My sliders are '68 to '69 series as they have the 7/16" lower mount bolts and one center fender mount bracket located behind the fork tubes.
    The front and rear fender mounting brackets (59103-52A) are the same from '54 through '69.
    The center mounting brackets (59107-52) was used from '54 through '70.
    MY QUESTIONS: Were there any differences in the 1959 through 1969 CH fender mounting? Were there any differences in where the center mount brackets were placed on the lower legs between the -52 and -68A series lower legs? I suspect that the answers to both questions are NO and I'll have to start tweaking the fender braces.
    Thanks!
    Bill Pedalino
    Huntington, New York
    AMCA 6755
    • 4775
    Bill,
    All the CH fenders are the same mounting in that time frame. Are you sure it is Sportster though and not a lightweight version?
    • billpedalino
      • Mar 2005
      • 1096
      Good point Robbie - no, I'm not sure that its not a Wizzer or other light-weight. I have another front fender in storage that I have to get to and compare. I bought this fender on Ebay years ago and it was advertised as a CH fender. From memory, it looked correct and I never questioned it. My guess is that the braces are bowed and must be re-aligned, but the light-weight fender is certainly possible... Thanks.
      Bill Pedalino
      AMCA 6755
