1968 xlch exhaust header question
  • bgreene30
    • May 2012
    • 21
    Hi, I was looking at a bike online for a 68 sportster.
    When I looked at the motor photo, i became leery as the front header pipe is very blue while the rear is nice and chrome.
    Leads me to assume, not sure if correct as I am not familiar with these motors, one cylinder is nice and hot the other is nice and cold.
    What are your thoughts?
  • dlxl66elxl
    • Jun 2011
    • 43
    Since day one the front cylinder on the Sportster runs hotter that the rear. If you run a colder plug in the front that the rear, you can get identical plug readings. If you run the same plugs, the front will read leaner.
    • bgreene30
      • May 2012
      • 21
      Thanks. Has nothing to do with health of motor then? What is typically done? Different plugs up front as suggested?
      • dlxl66elxl
        • Jun 2011
        • 43
        Champion J11Y up front and a J12Y in the rear is the setup you want to use.
