76 ironhead electronic ignition versus point system
  • ironhead john
    • Aug 2013
    • 6
    Thinking about going back to points on my 76 ironhead any input would be helpful ei versus points also would I have to switch out my coil thanks guys
  • vph-d
    • 1082
    If someone converted your 76 to some kind of electronic ignition, the coil is probably incompatible for points.
    VPH-D
      • 2030
      Most electronic ignitions use a 2.8-3.0 OHM coil ,points used 5.0 OHM.On many conversions this was overlooked.
      Test the resistance.You also need solid core non resistor wires for points.Why points...engines last more miles with electronic Ignition and have less maintenance
