I was going to replace the primary gasket on my 66 xlch and i noticed after I took of the cover that my cluitch hub has a bit of a wobble to it. I see in the manual that there is two bearings in the hub. Is that normal to have a bit of wobble in the hub? Any advice would be helpful. thanks Jack.
66 xlch clutch hub wobble normal ???
Tags: None
Dry clutch hub bearing replacement
JackOriginally posted by jackrabbitjack View PostI was going to replace the primary gasket on my 66 xlch and i noticed after I took of the cover that my cluitch hub has a bit of a wobble to it. I see in the manual that there is two bearings in the hub. Is that normal to have a bit of wobble in the hub? Any advice would be helpful. thanks Jack.
The clutch on the 66 has a single needle bearing and in my 47 years of screwing around with Magnito bikes this bearing is the highest failure rate item on the bike. Any wobble on the hub will result in a oil leak. I usually cut the bearing out with a carbide bit on a dremmel tool and SLOWLY press a new on it so it just touches the spacer. Beats re riveting the starter gear. Hopes this helps, Dave
