I am working on a 62xlh and want to use the correct nuts and bolts.The parts book is calling nut 7993 a flexloc but it is a nylock.On the brake drum to wheel nuts 7725 are flexloc Now I would like to know about the nuts for the gas tank,front motor mount and shocks they all use nut 7775 the book said flexloc but should they be nylock . Thanks. Mark
Hardware
Hardware
Hey Murph thanks for the input .I have seen your work over at caimag. That's what I am going for but you set the bar pretty high.Well I guess I have two order up some cad flexloc nuts thanks again.Originally posted by murph View PostIf the book says flexloc then it should be a flexloc. Gas tank, front motor mounts and shocks are all flexloc. Cad plated as well
