KHK and Sporty gear selector
  • John A
    • May 2012
    • 14
    Hi
    Working on my '56 KHK. The gear shifter cam assembly is worn with excessive tolerances. I happen to have a new '79-up assembly (the late style with the plunger pawls replaced with the long lever pawls) which fits fine and on the bench shifts through the gears with correct clearances between the shifter clutches.
    However, there are differences in the grooves in the cam plate between the detente positions. It looks like this is to reduce free movement in the shifter fork, keeping the shifter fork more precisely in position.
    Has anyone tried this retro-fit and can say it all works sweet?
    Thanks, John
  • kg993
    • 263
    I can't remember, does the 56 use a ball bearing detent? The later XL uses a plunger.
    Kerry
    Kerry AMCA # 15911
    • John A
      • May 2012
      • 14
      Thanks for your interest Kerry, the '56 KHK uses a plunger with a V-tip which matches the profile of the cam plate.
      John
      • John A
        • May 2012
        • 14
        I can now answer my own question. I've done about 1800 miles on the KHK in the last 6 months and it couldn't shift slicker or better. So the later assembly is good for retro fitting. Photo attached.khk lr (1).jpg
          • 4783
          Nice bike, but hate the horn...
          • John A
            • May 2012
            • 14
            But it is a blaster! Maybe find the correct horn one day, but they honk!
