V Twin sells a wrench (# 16-0414 on page 747) for the valve cover for 1929-1973 45 cu. in. flathead. The OEM part number for the wrench is 11806-31. Will this work for my 1956 KHK? If not, did Harley make a special wrench for the '56 KH model?
valve stem cover wrench for '56 KH
George Tinkham
Springfield, IL
www.virmc.com
AMCA # 1494
1941 Indian 841
1948 Indian Chief
1956 H-D KHK
1960 CH
1964 BMW R69S
1984 Moto Guzzi V65SpTags: None
Thank you. I bought that wrench.
The wrench works OK for the front 3 valve stem covers, but does not have enough clearance to get on the back cover. I have heard suggestions of using a strap wrench or the Vacuum brand pliers that I have for my Indian Chief. Does anyone have any other suggestions? Don't tell me Harley made a motorcycle that could not be maintained!George Tinkham
Springfield, IL
www.virmc.com
AMCA # 1494
1941 Indian 841
1948 Indian Chief
1956 H-D KHK
1960 CH
1964 BMW R69S
I gave up on the strap wrench idea because there is not enough room for it to work. What I am planning to do is to take a perfectly good 1 3/8" open end wrench with a 30 degree handle and cut metal from the outside of the jaws until the thing fits. It will be thicker and probably have better metal than the original Harley wrench; so, it just may work. If the jaws spread when used, I guess one could stack two wrenches and have a REALLY thick tool that should be strong enough.
How does this sound? Does anyone have a better idea?George Tinkham
Springfield, IL
www.virmc.com
AMCA # 1494
1941 Indian 841
1948 Indian Chief
1956 H-D KHK
1960 CH
1964 BMW R69S
I ended up filing the V Twin wrench until it fit. It still seems strong enough to do the job. It also helps to lift the rear intake valve stem cover so that the wrench has room to rotate more.George Tinkham
Springfield, IL
www.virmc.com
AMCA # 1494
1941 Indian 841
1948 Indian Chief
1956 H-D KHK
1960 CH
1964 BMW R69S
George Tinkham
Springfield, IL
www.virmc.com
AMCA # 1494
1941 Indian 841
1948 Indian Chief
1956 H-D KHK
1960 CH
1964 BMW R69S
You forgot the most important thing. 10 feet of bailing wire and a twister tool. I carry one with me were ever I go. This includes my truck. There are times these two can do sudden miracles. Bob L
That is what I keep in my Indian's saddle bag!George Tinkham
Springfield, IL
www.virmc.com
AMCA # 1494
1941 Indian 841
1948 Indian Chief
1956 H-D KHK
1960 CH
1964 BMW R69S
