compensating sprocket nut
  • militaryrider
    • May 2005
    • 104
    1982 flh 80 cubic inch shovelhead , I must remove the compensating sprocket nut , is this a right or left hand thread ? than k you
  • rousseau
    hillbilly member
    • Jul 2003
    • 261
    Compensator nut is right hand. Usually difficult to remove because people tend to use a lot of loctite. Nut on the clutch hub is left hand.
    • militaryrider
      • May 2005
      • 104
      Thank you ,
      • portagepan
        • Feb 2006
        • 580
        And the loctite is a good idea. Mike
