Alternative to the Buddy Seat
  • carpenterbill
    • Oct 2009
    • 24
    Hey guys I just got a 1966FLH. Love it! One problem that I am having though is the height of the buddy seat. I am only 5'7" and tend to be on my toes while straddling the bike. I have looked at new seats by Mustang and Corbin, but I think it would be a shame to not put a period replacement seat on. Also I dont really want to drill my rear fender for a mount bolt. I have seen some seats called Calafia on EBay. Any ideas? Did I mention I prefer a white seat? Thanks guys.
    • 4784
    You might want to try a frame mounted dual seat on your '66. It is the same seat as the buddy seat for Sportsters of the period and was an option on the FL. It is lower, and it comes in WHITE!
    Robbie
    • carpenterbill
      • Oct 2009
      • 24
      So the Sportster seat will mount to the FL? Does it require different brackets? I assume the front of the seat mounts to the T-bar mount on the frame. Where would the back of the seat mount? Shewwwww. Thanks.
      • Paquette
        • Mar 2004
        • 438
        Go with the earlier buddy seat that was only 2 inches thick. Harley dealers had them on the shelf late into the 60's because at the time , they were not cool, no one wanted them and they just were left on the shelf. --M--6671
        • Blupacer
          • Aug 2007
          • 88
          Originally posted by carpenterbill View Post
          So the Sportster seat will mount to the FL? Does it require different brackets? I assume the front of the seat mounts to the T-bar mount on the frame. Where would the back of the seat mount? SBuddhewwwww. Thanks.
          Buddyseat, H-D called them All Model sets came out in 1959, mounting parts kits for different models
          52511-65 Electra Glide
          52511-59 Duo-Glide
          52508-59 XLCH
          52508-61 XLH
          52508-67 XLH electric start 67 and later
          Steve
          Steve Cornish AMCA 6971
          TO MANY CLEVER PEOPLE NOT ENOUGH WISDOM
          • carpenterbill
            • Oct 2009
            • 24
            I can find the seats but am having great difficulty in finding the rear mounting brackets. I believe they mount to the rear shock stud. Any ideas on where I could locate a pair or if they make repops? Anyone got one (a bracket or the whole seat) laying around on a parts shelf?
            • jorrow
              • Feb 2008
              • 347
              My friend has several and would be glad to sell you one. 817-275-6101.
              • carpenterbill
                • Oct 2009
                • 24
                I will try to call tomorrow. Just to be sure I need the FLH style not Sportster. Thanks for all of your help.
                • SFMike
                  • Nov 2010
                  • 12
                  I have owned several 65's and 67's.
                  At 6 feet tall, I have found all buddy seat combos to dang high and uncomfortable.
                  I always went with a superglide type seat-one little hole in the fender easily fixed.
                  Gave me full control of the machine with both feets firmly on Terra Firma.
                  Just my solution.
                  • yjamest
                    • Oct 2010
                    • 6
                    i have a 69 flh with a corbin two piece and luv it low to the ground and comfey and looks great
                    • carpenterbill
                      • Oct 2009
                      • 24
                      I appreciate all the comments but I have to stress I am wanting to use something that was available in 1966.
                      • Sargehere
                        Member since 1972
                        • Jul 2006
                        • 971
                        Another avenue of approach is to have a good seat man, Paquette, Worshamcastle, or someone good with Harley seats, build you a period-seat using thinner foam than stock. That's been done often to get the ultimate seat height down, and hardly noticeable.
                        Gerry Lyons #607
                        http://www.37ul.com/
                        • Rooster
                          • Mar 2009
                          • 543
                          You only notice it when you're off the bike, not riding it. These bikes are for riding, aren't they?
