70 Electra Glide Exhaust
  • r.mac
    student
    • Dec 2007
    • 25
    anyone know what pipes I need to add a kicker to this bike and keep the dual exhausts? thanks
  • vph-d
    • 1082
    I don't believe the factory ever offered any kick start cone dresser systems. It is possible Paughco or someone may offer something, though. If you are willing to ditch the duals, your options increase.
    VPH-D
    • Kozy
      • Feb 2004
      • 129
      Dresser pipes
      I have a set of Paughco pipes that clear the kick start on my '75. Haven't been able to find a heat shield for the rear head pipe though.
      • murph
        1959 xlch
        • Jun 2009
        • 226
        I did this to a 75 flh for a friend of mine several years ago, I believe the pipes were pauchgo. You will neatly have to cut the stock heat shields for the front header and buy one for a late generator shovel for the rear. I prefer buying aftermarket heat shields to molest as opposed to desicrating the originals. Keep the stock exhaust intact incase your mind changes later.
        1959 XLCH
        • portagepan
          • Feb 2006
          • 580
          My '72 FLH had a kicker on it when I bought it. It just had two exhaust pipes with a squish pipe to clear the kicker. It is a two into one system.
          Mike
            • 5948
            Mike
            My '72 Stupid-Glide was also kicker. No electric start on it.
              • 4775
              You can use the '69 and earlier header pipes if you don't mind the front pipe looking odd sitting out in front of ther engine where there is no cam cover.
              Robbie
              • pat triplett
                • Mar 2008
                • 18
                paucho makes a set of over-under pipes[front pipe under kicker and rear goes over]. also theres true duels[front straight back and rear turns left and comes out above silinoid,running back] hope that helps
                hawg farmer
                • bmh
                  • Feb 2007
                  • 901
                  Superglide pipes are completely different than FL pipes. the FX pipes will not clear the big battery for the electric leg.
                  Brian Howard AMCA#5866
                  • pat triplett
                    • Mar 2008
                    • 18
                    oop's i thought it was for 1970 flh adding kicker; did make me think so i went out to the e-glide shed, i have a set brand new,now thats the over-unders,there made to clear for flh, my 1972 flh came stock with electric/kick so is my 73 and my 74, my 66 came with starter/kicker, i probly read wrong ,hey you guys have a good day, think stock exhaust;
                    hawg farmer
                    • r.mac
                      student
                      • Dec 2007
                      • 25
                      you've got a shed for just e-glides? where can i get one of those! it is a 70 i want to put a kicker on. couldn't i just use a later stock exhaust like your 72-4? the swap meets around the corner here in denver so i'm hopeing to find one that'll work.
                      • pat triplett
                        • Mar 2008
                        • 18
                        ride on,hope you find something, should have kicker already? could be swaped out with later model . if you cant find any,true duelles will fit,i can make a call and one of my friends just put a set of duelles on his,think his is 71.now on my 72 glide parts fit 68 to 72 on most parts if that helps,keep us posted and happy hollidays.
                        hawg farmer
