My 67 FLH has a wobble in the front end. It starts around 28-30 MPH, and goes away at 40-42. Wheels are checked and found to be true. Swapped front to rear, rear to front. What is the next thing to check?
Seat post bushing.Be sure to visit;
wheel bearings are touchy on 67-72. one bearing is in the wheel hub and the other side is in the brake drum on those years. neck bearings to loose or too tight will cause it tooLast edited by flat-happy; 09-20-2009, 12:09 AM.
frontend wobble
I have had the same thing happen to me on a full dresser and it was a under inflated tire but you say you swaped out the front and rear could be a cracked in your frame they seem to break under the tranny and on the down tube below the battery box on the primary side,I would also check the neck bearings.. good luck
Now, I know Chris personally, and I trust everything he says --- (usually ---) But I think this is the first time I've heard sloppy seat post bushings as causing a wheel wobble. My first suspect is always the front tire, if it's developed any weird wear patterns. Then you have to consider steering head bearings and the tension on them. A fall-away test will determine that, but any cables -- such as front brake cable-- should be disconnected so as to not interfere. Then there's wheel bearings, both front and rear, and not to forget rear wheel alignment. A windshield will aggravate a wobble, also.
67 FLH front end wobble
I have tightend the stem nut, removed the solo seat and drove with a frame mounted seat, still have the wobble. So I think that eliminates the seat post bushings, and the neck bearings. Unless there is something I am missing. Anybody have any thoughts? Tires, have 95% tread remaining, they are Yokahama brand, my tire guy said that they are old remakes, maybe twenty years or more. On the sidewall it says " H.D.S. Classic " size is MT90-16. The tread patteren is similar to the old Goodyear Speed Grip. Someone mentioned wheel bearings, I have swapped wheels front to back, so I would think that at least eliminates the bearings in the hubs. That leaves the bearing in the front brake hub. What would I check for on the front drum and bearing?
