exhaust
  • exhaust
    I have a 76 FLH. Can anyone give me the OHM numbers for the correct exhaust that should be on this bike. Of course if anybody has a suguestion of an exhaust that works better, looks good and is acceptable please advise. I'm trying to keep it as stock as possible. Also....along with the numbers if you have a good quality supplier...it would be great. At the present time I'm running straight pipes....although feeling obnoxious is cool sometimes...it's getting old. I also feel the bike would run better with correct exhaust. Installed is an SS carb which is working out very well.
    thanks all
    You didn't specify single or duals. This is from a parts book published for the 76 model year.
    Single..65435-70 pipe & 65239-41A black muffler, or 65240-41A chrome muffler (extra quiet). There are heat sheilds also.
    Dual..65496-70 & 65494-70 pipes and 65242-70A mufflers. Again there are sheilds.
    Brian Howard AMCA#5866
