Steering jam nut...how tight?
  • OldHog66
    • Jan 2009
    • 113
    Manual doesn't really talk about how tight you want the steering jam nut.
    I have it (at this moment) and without putting on the top bracket and nut, just tight enough that there is no up and down play and if i turn the head to 45 degrees it will fall the rest of the way left or right (this is without forks, just triple tree)..
    any rules of thumb?
    • 5946
    Check page 53 of Palmer's book.
    • OldHog66
      • Jan 2009
      • 113
      Chris,
      thanks.... I knew I had seen it somewhere and forgot to check Palmers book!
      • Rooster
        • Mar 2009
        • 543
        If there's one thing I've learned--- it's check The Book first! Then the Service Manual..!
