Innertube size
  • OldHog66
    • Jan 2009
    • 113
    Innertube size
    Hey,
    I bought some 5.00 x 16 Cokers for my restoration, but I'll be damned if I can find 5.00 x 16 rubber side valve tubes.. The "regular" vendors (and what I ordered) carry 5.10 x 16 ... any issues running 5.10 tubes with 5.00 tires?
    thanks..
    OldHog66
    Steve
  • Magic
    Magic
    • Dec 2002
    • 282
    Not a problem
    That's what we all do...It'll be fine, it's such a small diameter difference. Under size tube in my thought would be wrong. Merlin in Pa.
    • bmh
      • Feb 2007
      • 901
      Didn't tubes used to be marked 5.00\5.10X16? Also Kick Start MC parts lists tubes as 5.00X16, note says to call for specifics.
      Brian Howard AMCA#5866
      • OldHog66
        • Jan 2009
        • 113
        Thanks guys
        I thought the same thing...but then I thought I read somewhere one time that you should not use 5.10 tubes on 5.00 tires...
        appreciate the quick responses!!
        Thanks again
        Steve
