internal throttle push or pull
  • internal throttle push or pull
    what is the set up for early 70 internal throttle push seems to work better can you change the grips to change from push to pull
    john renoe #1952
    bendix carb 1971 and later
    1971 and later bendix carb is a pull
    1970 and older is push
      thanx
      for the answer
      john renoe #1952
