OK Guys I need your expertise once again,
I have what will be for most of you here, an easy question. I have a 67 FLH. The Rocker screws are seeping out oil which coats the side of my bike when I ride it. I can actually start the bike and sit watching it weep. I tried loosening the plastic headed acorn nuts on the far side of the head thinking I would then be able to loosen that mammouth screw on the starboard side, (I had a boat,LOL) to no avail. It actually turned, but would not come out. I want to see what shape the "O" ring is in, if there is still one there. Am I on the right track here? FYI...It's the front screw on each head that is seeping oil.
