1970 FL 4 Speed
  • sieber60
    • Jul 2014
    • 83
    1970 FL 4 Speed
    I know this is a common problem for many reasons, however, I am thinking that I have a shift fork problem, so here is what's going on. Just replaced the clutch hup, basket and compensator. The bike seems to shift okay not great but.... the big problem is I can't get it into neutral at an idle. I can shift into neutral at a roll but not at a complete stop.
    I have gone back over clutch adjustment procedure, primary chain adjustment (not too tight) alignment etc.
    This bike came to me needing a lot of TLC... and I don't have a lot of history on it. Based on a many of the other repairs I have made the last person or persons that worked on it lacked experience.
    Would like to get some thoughts in case I am missing something before I pull the transmission out.
    John
  • 41craig
    • Nov 2010
    • 411
    I replaced the clutch hub bearing plate (part # 37576-41) with a RamJett Retainer. It keeps the clutch basket from floating in and out which makes for a grabby clutch. I'm not sure if the Co. is still in business, but V-Twin and other parts Co's. sell a similar item.
    • sieber60
      • Jul 2014
      • 83
      Thanks, that maybe an option. One thing I neglected to share is the neutral light is flickering off and on in first gear.
      • dukekleman
        • Jul 2022
        • 597
        John,
        Does it shift into neutral normal with the engine shut off?
        Being you stated that the motorcycle will shift into neutral properly at rolling speed, I would suspect it shifts into neutral when the engine is shut off.
        If the above statements are true, it would indicate that you have a clutch assembly unit issue and/or a primary drive system alignment issue.
        Hope this helps,
        Duke Kleman
          • 4791
          Is the ratchet top timed correctly? (in the manual). Is the neutral detent set to hold the drum?(in the manual).
