1968 rear brake question
  • ldfly112
    • Sep 2017
    • 146
    I am restoring a 1968 flh and need a rear brake hub. It looks like there are different options available cast or stamped steel . new or used any opinions Thanks if you can help
    • 4789
    Your question is confusing. Do you mean Hub? or Brake Drum" All the juice brake drums are cast iron for '68-72. All use the commonly called mid-star hub which is a welded up assembly of stamped and machined parts.
    • ldfly112
      • Sep 2017
      • 146
      I have a mid star brake drum on the front . Did they use a mid star hub on the back wheel also.
        • 4789
        Yes, the wheels are set up to be interchangeable, they are identical.
