Pogo Seat Comfort
  • RodFun
    • Jul 2018
    • 18
    Pogo Seat Comfort
    Maybe that title is an oxymoron.
    I love that my 76 Shovel has a pogo seat. When I first looked at the bike, after we made the deal my buddy said to me, "did you see him remove that chew toy from under the seat before you went for a test ride?" I did not, as I was focused on everything else. But now I get it. I'm 6' 2" and weigh 215 in my birthday suit. When I took the bike to my shop to have them go through it, I asked them to install the stronger pogo spring, which was obvious. I also replaced the t-bar bushing to eliminate lateral movement and the seat feels good. But I do bottom out occasionally and I also feel like I'm leaning backwards a bit when I ride, so I think I have the pogo pretty well compressed.
    Instead of a chew toy to absorb the bumps, I was wondering if I could put a rubber bumper around the pogo shaft, kind of like a piece of pipe insulation but very tough. Also wondering if I can elevate the seat off the pogo shaft a little more so when I compress it I don't feel like I'm leaning back.
    I'm sure others have come up with creative solutions so I am just putting this out there for any ideas.
    Thanks!
    Rod
    This gallery has 1 photos.
    • 8233
    Traditionally, Rod,
    Everybody had a box of spent OHV outer valve springs, and just tossed one over the post.
    (Indians used a blasphemous harley springer upper fork spring.)
    How many you need?
    • RodFun
      • Jul 2018
      • 18
      Aha! Now I remember reading that somewhere. Sounds perfect. Looking at pics they seem to be about 3", which would probably do it. But maybe two.
      I also found this great article about adjusting the "spring preload" on a '64 panhead, which probably applies to my '76 shovel. I may try both solutions. But I can see that the OHV springs make for an easy quick fix. I include this link for anyone looking for solutions:
      How to adjust a Harley pogo seat on a Panhead, including seat post removal, spring preload tightening, and reinstallation.
      • droptopford
        • Jan 2010
        • 359
        The ultimate solution for this issue is a set of springs from 'The Spring Man'. He sold them through the AMCA mag for years. He's no longer in business but I know he sold his inventory to Colony. Don't know if they have any sets left but contacting them is worth a try. They are adaptable/rearrangeable to both rigid and swingarm frames.
        By the way... I have a set in all of my Springseat bikes. Same size and weight as you and have yet to bottom out once. Good luck!
        • chuckthebeatertruck
          • Jun 2018
          • 693
          Just so you know; KONG does make the "chew toy" in black . . .and they work extremely well.
          Swapping out a police solo spring for a KONG is a relatively common solution for heavier riders on late model bikes. The KONG is chosen because it doesn't break down and is about the perfect compliance rate.
          Oh, and you can make a donut out of them and slip it over the seat post if you like.
          • RodFun
            • Jul 2018
            • 18
            Ha! I love it. Which chew toy, KONG as many.
              • Jun 2018
              • 693
              Kong extreme chew toy, size large.
              The extreme comes in black, the regular in red. Under 175 pounds the regular is ok. Over 175, extreme is better.
              On late model police solos it’s a simple fit. On a pogo a little more involved.
              By me, the Kong extreme is 13-15 bucks.
              • PRG
                • Nov 2006
                • 612
                Howdy sir,
                Appears your seat uses studs for the two rear anchor points to the T bar blade like the original police solo. Just got a new Corbin Gentry which uses threaded bosses, bolts and provided spacers to offset that raised nose. Yours also appears to have the same/nearly same over padding of the nose as mine, original police solos like I ran on this machine for over 35 years before the cover rotted off are much lower. I’m of large weight and dimension and prefer sitting “in” my bike rather than on “top” of it, the better for wheeling it around like a hula hoop below my waist, so prefer the lowest saddle position attainable. These “glides” do just that down the road being softly sprung so I removed my spring and cut a steel tubular sleeve to my preferred height to just clear that chrome cover and slipped it over my pogo. This new seat called for something different, dispensed with the sleeve, refitted the spring as just a place holder, made a bracket to mount this grab rail with rubber bumpers on the bottom of the rear loops. Under way it settles down nicely on the chrome cover.
                Cheerio,
                Peter
                #6510
                • RodFun
                  • Jul 2018
                  • 18
                  Nice setup, PRG!
                  My goal is to keep this FLH with the previous owner's "design" as much as possible, which is what attracted me to this bike in the first place. So I am going to try and make this seat and post work.
                  When I spoke to my mechanic about the heavier spring installation he did, he thought maybe they twisted up the pre-load a lot. So perhaps if I rolled that back a bit the post would raise up higher and offer more spring range. I don't know, but before I get into it I'm going to try the couple hacks mentioned above and see how it does. Also the more I ride it the more I'm figuring out how to position myself. I'm thinking maybe if I tilt the bars down a bit it will shift my lean forward a little and maybe eliminate feeling like I'm falling back. Then throw on a chew toy and "Bob's your Uncle". Thanks for all the feedback. I'll be stopping in at the Greenfield National on this bike in July if anyone is in the Western MA area.
                  Rod.
                  • sswaney
                    • 302
                    does anyone know if Dave Croft is still selling seat post springs ? need some for a 1981 heritage. thanks
                    • paddy
                      • Apr 2014
                      • 219
                      No he sold it to kurt at colony_usa 3081-7
