1972 FLH plating / paint
  • jmorgan
    • Nov 2025
    • 13
    Restoring1972 Harley FLH......and curious if anyone knows if the plating on the steel parts is zinc or cadmium.....and if anyone has found a spray paint that matches closely to the correct color and sheen?? I am NOT getting the parts plated. The Eastwood Detail Gray is too dark.....and I have not tired their silver cad yet....but would be my next step. I see that Rustoleum and others have a Cold Galvaning ZINC coating......but not sure if that is a good option...does it stick, does it look correct???
  • Saddletramp
    New Old Member
    • Aug 2011
    • 126
    jmorgan,
    I purchased some of the Eastwood Silver Cad but haven't tried it yet. I'm interested to know how it turns out.
    I painted a couple of small hardware parts with Rustoleum "Peppercorn" gray which very closely matches some of my factory parkerized parts. But now I set myself up to do my own parkerizing.
    I will mostly be doing Magnesium Phosphate parkerizing. Though I may do a couple of parts with Zinc Phosphate solution which gives a lighter gray, though still not as bright as Zinc coating or plating.
    This is probably not helpful but let us know how the Silver Cad works. I won't get to spray mine for a month or so.
    James
    • otis71
      • Jul 2015
      • 597
      The parts would be cad in 72. I wasn’t happy with Eastwood spray cad. Looks too shiny in my opinion. Harley Davidson hi temp silver looks better to but still not like real cad. Real cad is fairly inexpensive but I’ve been having trouble in recent years with more than one vendor with it prematurely turning black.
      • jmorgan
        • Nov 2025
        • 13
        As I said,....its not worth it for my intended use of this FLH, which is to ride it alot, to worry about attaining an accurate reproduction of some cad plating....and as others have reported,...there are many versions of cad, so unless you find the original and accurate version, everything is a fake. I am okay with fake. I want it close, and that is good enough. Eastwood Silver Cad paint is on order and will do....whatever it turns out to look like. Most of the parts are barely visible on the bike, hidden behind parts, behine covers, etc. Thanks for the input and sorry to the purists.
        • jmorgan
          • Nov 2025
          • 13
          Got the Eastwood Silver Cad paint, and painted all the appropriate parts. It is NOT a perfect match to real cadmium plating....a little more "sparkly" that it should be, but some of that can be minimized by technique. If you spray it lightly, i.e. farther back, less "wet", it lays down a little and matches closer to the real thing. It IS the best match I have found of any silver paints, so that is good, and its good enough for me.
          • BigLakeBob
            • 2766
            Looks good, thanks for sharing the info on the paint. I used a PlastiKote silver in the past but have not been able to find it recently. I treat my 69 the same way and will probably get some of the Eastern.
            Bob Rice #6738
              • 2030
              Customer used Eastwood silver cad & did quite well at Judging with his '41 ULH
              • Saddletramp
                New Old Member
                • Aug 2011
                • 126
                It does look good. I will be happy if mine turns out looking like that. Thanks.
                • Rodger Brandstatter
                  • Aug 2011
                  • 53
                  We use Columbia Coatings anodized aluminum powder at our shop for Harley and Indian parts that were originally cad plated. It looks close to cad and has the benefits of powder coating.
