Questions about a 1978 1/2 FLH
  • JordanSpreader
    • Sep 2022
    • 24
    I brought home a 1978 80cu FLH and I have a few questions while I wait for some parts and a manual to arrive in the mail. This is my first shovelhead so I'm pretty unfamiliar with them.
    What is the correct way for the fuel lines to be routed? Currently, a crossover line is routed between the head and the front down tube connecting the right and left tank. Should this line be on the inside of the frame up against the head or should it be in front of the frame to keep it away from the engine?
    Also, the fuel line from the petcock to the carb is routed the long way going forward of the engine around the front down tube and then back to the carb. Is this correct or should it go from the petcock and between the cylinders to the carb?
    I have read about hard bag lids flying off. Can someone post a photo of a modification you made to keep this from happening? I've heard of drilling the front tab and using a pin, or modifying the lock.
    This bike is equipped with a center stand, or I think it's called a service stand. Just out of curiosity, what's the method for getting the bike up on the stand?
  • otis71
    • Jul 2015
    • 593
    Crossover goes to the outer of the down tubes, supply line goes between cylinders with a wire support. I use the small bungee cords hooked to the brackets across the lids to secure them. A lot of people do drill the front clip and put a hitch pin in it.
    • vph-d
      • 1082
      Back then, pretty much all of the FLHs we sold had the front bad clip drilled and a clip installed.
      vph-d
      • 1937hd
        • Nov 2016
        • 62
        If you replace the old foam rubber gasket in the lid they usually don't fly off
        • droptopford
          • Jan 2010
          • 354
          +1. I bought some black rubber (weather insulation) strips from the local hardware store and glued them to the lids. They create enough pressure against the latch to keep them in place. Daily rider for 40 years now and the lids are still there.
          Also went back to points and condenser under the cone. IIRC, the 78 1/2 electronic ignition wasn't the best.
          Also, I know the repaint was heresy but I never was a big fan of the original '78 look.
          • vph-d
            • 1082
            There was a75th Anniversary Ride to the factory in the summer of 1978.We had John Davidson and some other factory guys visit our dealership. IIRC, more than 1 of their electronic ignition modules failed while in the Chicago-land area. We had to strip bikes on the floor, as there were no replacements available
            vph-d
            • DEEBS47Chief1991
              Living The Dream
              • Jan 2023
              • 1256
              The Dyna-S electronic ignition is the best choice for Shovels and Evos. I have been installing these for over 30 years. Very reliable. Always use a 5 ohm coil. 3 ohm coils get hot and start to crack after about 10 years.
