1966 shovelhead
  • murph
    1959 xlch
    • Jun 2009
    • 226
    I guess the next cheapest thing is the relay, and yes there is one under the battery box. I'll give that a go and report back. Thanks guys.
    1959 XLCH
    • murph
      1959 xlch
      • Jun 2009
      • 226
      I found out what is clicking so rapidly, It's the starter solenoid. The bendix drive engages and then the starter solenoid rapidly clicks back and forth. The starter relay is grounded to the frame as Duffy said. So are we still going with the relay? Thanks Murph
      1959 XLCH
      • Lyle Manheimer
        • Mar 2008
        • 191
        Yes. Solenoid is operated by the relay contacts, which may be corroded. High resistance.
          • 2021
          Solenoids are not all the same quality.....Standard Motor Products STS1 is better than most others..J&P Cycles 363-474
          • murph
            1959 xlch
            • Jun 2009
            • 226
            Thanks guys, I did find an NOS relay. I keep you posted when it gets here.
            1959 XLCH
            • murph
              1959 xlch
              • Jun 2009
              • 226
              Well, after nos relay lost in the mail and finally getting here after I ordered another one, I installed it today and still the same problem with the starter solenoid clicking rapidly when the starter button is pushed. So just to refresh what I did with no change as of yet.
              Brand new bendix drive installed
              Took a known working battery from my shovelhead and tried it no change, put it back in my shovelhead and that fired right back up.
              Swapped out the starter solenoid known to work and no change.
              Installed nos starter relay and no change. I tested both according to the manual and test bulb and tested correctly. I left the nos one on there.
              I am currently looking into the push button but have doubts that's it.
              WHAT NEXT?? Thanks Guys I'm frustrated
              1959 XLCH
              • Lyle Manheimer
                • Mar 2008
                • 191
                Murph,
                Push button is about all that is left. With a good voltmeter check battery terminal voltage. Plus side of battery to negative side. Also check plus to frame or engine, should be the same. Take the voltmeter and attach the red + lead to the relay from the push button and the - negative lead to frame or engine. Push the start button and you should read very close to battery terminal voltage. If not you either have a bad pushbutton or a high resistance connection. Meaning you need to check all connections between the push button and the relay.
                You can also lift the wire from the push button at the relay and take a jumper from the + side of the battery and momentarily touch it to the relay where you lifted the wire and if the solenoid engages you have definitely found the problem,
                • murph
                  1959 xlch
                  • Jun 2009
                  • 226
                  Thankyou, I was going to ask is there a way to jump out the push button to see if that can be ruled out. This bike has been rewired at some point in its life. I pulled up the push button last night to investigate and found original wiring on it that does not match with the wire at the other ends which tells me there's a splice somewhere. If I'm reading the wiring diagram correctly the wire from the start button to the relay is #3 and the one I need to use to jump out? I will continue my quest and report back. Thanks again for all the help.
                  1959 XLCH
                  • dukekleman
                    • Jul 2022
                    • 594
                    Murphy,
                    If you are familiar with "voltage drop testing" please perform the test and it will lead you right to the problem. Quickly and accurately.
                    You can voltage drop the contacts and wiring at the starter button, relay and solenoid . It will show up. Remember larger wire gauge has a acceptable limit of 0.6 VDC Or less combined while smaller gauge wire may be up to approximately 1.0 VDC or less combined.
                    The smaller the gauge along with longer length, the higher the voltage drop.
                    Along with most everything, it is typically a accumulation of faults that need addressing. Contacts, wires, crimps, etc...
                    Hope this helps,
                    Duke Kleman
                    • murph
                      1959 xlch
                      • Jun 2009
                      • 226
                      I tried removing the #3 wire from the relay and temp touching it with a jumper and the results are the same rapid clicking from the solenoid. I completely took the starter button out of the equation by removing it from the terminals. I get 12 volts from all the points suggested. I am unfamiliar with the voltage drop test but when I hit the starter button the battery voltage drops from 12 to 5 volts.
                      1959 XLCH
                      • joe fxs fxr
                        • Dec 2020
                        • 686
                        Rapid clicking always meant dead battery to me. 5 volts is definitely dead!
                        AMCA #41287
                        1971 Sprint SS350 project
                        1972 FX Boattail Night Train
                        1972 Sportster project
                        1973 HD Golf Cart project
                        1989 Springer Softail project
                        2020 Heritage Classic 114
                        • murph
                          1959 xlch
                          • Jun 2009
                          • 226
                          #27
                          I agree, but I took the battery out of MY shovelhead that starts without issues and installed it in this bike and nothing changed as far as the rapid clicking. I put it back in my bike and it fires right up.
                          1959 XLCH
                          • jim d
                            • Sep 2010
                            • 279
                            #28
                            I have a piece cut from an old outer primary cover that you can bolt on to support the starter drive. That way you can try the starter and observe if there is a mechanical reason that may be stopping it from working. I just thought that maybe there is something that binding up to stop it from turning over and also pulling the voltage way down when you try to start it. What happens if you remove the plugs and try to start it?
                            Jim D
                            • jim d
                              • Sep 2010
                              • 279
                              #29
                              You can borrow my primary support test piece if you think it would help. I think we are probably pretty close to each other.
                              Jim D
                              • jorrow
                                • Feb 2008
                                • 347
                                #30
                                Murph, try loosening the solenoid bolts a turn, and hitting the starter button. It might be in a bind and needs to readjust. If it starts right up, retighten.
