primary oil line
  • primary oil line
    Does anybody have a source for the shiny small oil line that goes from the tube in the top of the oil pump over to the primary? It's the line that oils the primary chain. It appears to be 3/16" ID and somewhere around 1/4" OD. The one I have looks like it was made of vinyl, but I can't believe that would hold up to hot oil. The smallest 3/16" ID rubber hose I can find is 5/16" OD and isn't really flexible enough to make the bend from the tube at the pump over to the chain case.
    I use part number 5119K42 from McMaster Carr.
    3/16" ID 5/16" OD 1/16" wall and 60A duro
    -10F to 400F
    Hope this helps,
    Duke
      I'll try it....thanks
        I got some small diameter vacuum hose from Napa for my Shovel last summer. I's not as small as the oem line, but doesn't look too bad.
        vph-d
          Thanks for the tip...somebody PMed me about hose from McMaster Carr, so I bought a couple feet. It's coming today...Ill see how it fits and looks
            -10F to 400F
            Hope this helps,
            Duke
            Works great. Flexible and I like that it's not shiny like the one I had on there.....Cheers....Omar
              Glad it worked out well for you.
