Clutch issue 76 FLH
  • OWG
    • Apr 2017
    • 12
    Clutch issue 76 FLH
    I'm having an issue with my clutch slipping when I accelerate hard especially in 3rd or 4th gear. I have replaced the friction plates (organic),steel discs, and put the 52 bearing kit in to replace the factory bearings. Have adjusted the clutch as follows: took all tension off the lever then adjusted the screw to just touching on throw out bearing then backed off 1/2 turn and locked it down. Then adjusted lever to 1/8 in play. I have done this 3 times but the clutch still slips. Also adjusted pressure plate to 1 in. After installing new springs. Still slips
    Any ideas would be appreciated.
    • 2018
    I think that the 1" spring adjustment is really a recommended starting point. I would try tightening the spring one click and see if that helps. I have to admit however that usually the factory 1" is good enough - some books say 15/16".
    • OWG
      • Apr 2017
      • 12
      Thanks Jerry, Forgot to mention that it is a big bore motor if that makes a difference.
      • joe fxs fxr
        • Dec 2020
        • 697
        IDK about the FLH clutch, but for the FX clutch you have to set the cable to get the clutch arm about 1/2" from the starter. Try that first then re-adjust. It may not help, so then go with a half turn tighter on the clutch nuts. You may need stiffer (non-stock) springs if your pushing a lot of torque thru the clutch, whereupon the clutch arm adjustment will help with lever effort.
        AMCA #41287
        1971 Sprint SS350 project
        1972 FX Boattail Night Train
        1972 Sportster project
        1973 HD Golf Cart project
        1989 Springer Softail project
        2020 Heritage Classic 114
        • Buster
          • 384
          Do you have the original type pressure plate or the aftermarket aluminum type. I had this same problem with aftermarket aluminum type. Some of the aftermarket require different adjustment at the pressure plate then manual shows for oem type. My clutch would slip when under load then engage suddenly.
          • Carl Olsen
            • Jan 2002
            • 261
            Put a BDL competitor clutch in it and say goodby to the slipping clutch on your big inch motor.
            Carl
            • dukekleman
              • Jul 2022
              • 595
              I'm with Carl,
              when it comes to the original design and the increase in torque you are likely making now, you are best off updating to a replacement unit made by many companies like BDL, API, Barnett, Rivera Primo, etc...some of these mentioned use coil spring yet while others use diaphragm. Regardless your clutch will work and perform as required.
                • 2030
                I agree with Carl & Dukekleman.The diaphram units can be a little tricky to setup on '52-'67 mousetrap bikes,but work great once setup.
                The '70-'77 service manual shows 1-1/32" for stock setup.
                • OWG
                  • Apr 2017
                  • 12
                  Thanks, y'all have been very helpful.
