FLH Mechanical Tach
  • Bsick
    • Mar 2019
    • 12
    FLH Mechanical Tach
    Hi All
    I have a new to me 66 ish Police bike. It has a mechanical tach with Harley logo and distributor drive. I have never seen one. Is the Tach body Sportster? Aeromacci? Big twin? It needs a cable and possible rebuild. Any idea on part numbers? Any parts available out there? Who might rebuild it if needed?
    This gallery has 2 photos.
    • 4784
    As it says on it, the maker is Smiths. It is a magnetic instrument from England. H-D used them for many years as an accessory as well as OEM on Sportster models. One of the major US service providers for Smiths is Nisonger Instruments. The glass and bezel are common to most British motorcycles of the 60s.
    Nisonger Instruments is a full-service supplier of Smiths Instruments gauges and high performance components and trim items for Shelby Cobras and other high-performance applications.
    • Bsick
      • Mar 2019
      • 12
      Guess I never noticed a tach on an FLH... I certainly will investigate more.. I wonder if the cable has an HD part number or maybe Nisonger can make me one... Length and routing is going to be the question... Rubone, Do you know of anyone making or has OEM volume controls for receive only radios?
        • 4784
        The part numbers are in the parts books of the era. The tach kit was an accessory item and appears in the accessory catalogs.
        As for radio controls I have never seen one out there. I acquired mine over 20 years ago and had looked for a good ten before then.
        • jorrow
          • Feb 2008
          • 347
          The part # is 92062-65. The cables are non-existent. The other parts such as the ones you already possess show up time and again. That should tell you something. Perhaps get several cores made. Good luck.
          • jorrow
            • Feb 2008
            • 347
            Heres the core. https://www.ebay.com/itm/16510595699...3ABFBMwrS5sftf
            • murph
              1959 xlch
              • Jun 2009
              • 226
              Here it is on my 68 FLH, John Bordas repairs them.
              1959 XLCH
              • Bsick
                • Mar 2019
                • 12
                Thanks for the reply!!! Any chance I can get a length on the cable? I will surely ask John if he has or can make them....
                • ryan
                  • Mar 2017
                  • 610
                  Does your headlight bucket have a hole in it to run the cable through, I was told no hole needed to be drilled??? You have the correct tach for the FL. I bought a new cable for mine a couple of years ago, I just ordered the factory part number and two styles were available, the plastic sheathed and the metal casing.
                  I just had a speedometer restored by John Borda and I asked him about looking at my tach and he told me he could clean the inside assy, clean or replace the glass and glass retainer.
                  • zig1
                    • Jul 2007
                    • 51
                    I have measured the cable on my tacho , the outer is 29 inches and the inner is 29 3/4 in . I think a hole would have to drilled thru the headlight nacelle , as the cable exits the tach straight towards the headlight
                      • 5950
                      I bet that Stan at vintage Rust can make one for you.20190712_112357 (1).jpg
                      • ryan
                        • Mar 2017
                        • 610
                        The replacement bearing part number for the timer tachometer drive is: NICE 1601 DC
