Shovelhead spark plug inserts
  • Pete Engelman
    • Apr 2018
    • 147
    I removed the heads from my 1966 FL Police Special to replace the buggered thread inserts. I removed the top portion with an easy out but a few threads remained. A previous owner installed long reach inserts. I was able to get the bottom portion out. It appeared that a pin was holding the bottom of the insert. I gave it a tap with a punch and it came out easily but left a hole about 1/4'' deep and 1/16'' wide at the bottom the hole a couple of threads above the combustion chamber I'm going to have to run a long insert again to cover this hole to prevent a hot spot. I'm running 8:1 pistons so I have a bit more room and thought I would run a medium reach plug to get closer to the combustion chamber. I use J12YC plugs that work great in an old Shovel does anyone run a good medium reach plug in a shovel that doesn't foul easily? or has anyone had to deal with this with a better idea. I'm going to try and attach a couple of pix
    Pete
  • TomL
    • Jan 2018
    • 109
    Long reach thread inserts in 66 Heads? Are you sure you have the correct heads?
    • Pete Engelman
      • Apr 2018
      • 147
      yes they are early short reach heads but I had to use a long insert to cover the hole at the bottom a previous owner drilled in the head to install a pin to hold his spark plug inserts in. I installed long reach but cut the bottom portion flush with the combustion chamber to cover the hole
