O ring thickness
  • 1970 XLCH
    • Nov 2010
    • 177
    O ring thickness
    Anyone know what thickness the o ring is that goes between the engine & the primary on a '71 FLH ? I've got a James gasket set and there are three of them . Thanks , Mike
  • pan620
    • Oct 2016
    • 223
    The ones I have in stock are Cometic and measure aprox. .070. It should be the the skinny one in you kit.
    • Lyle Manheimer
      • Mar 2008
      • 193
      Be careful. If you use the wrong one, when you torque the inner primary, you will break the ear on the front of the primary. The thin one is the correct one.
      • 1970 XLCH
        • Nov 2010
        • 177
        Thank you for the help , Mike
