Seized in pogo
  • Pete Engelman
    • Apr 2018
    • 147
    Seized in pogo
    Does anyone out there have any tricks to free up a seized in pogo. My friend has a 1964 pan head with this problem. I thought about using a slide hammer and some muratic acid
  • 55tmm
    • Dec 2009
    • 158
    Do a search in the Panheads section back in Sept of 2010, there was as topic about stuck seat posts, I had a few stuck pretty bad, take your time, you'll get it out.
      • 6012
      A slide hammer is a good idea, along with lots of lubricant. As soon as you can get the seat post to move up and down a bit, you're on your way. However, real aggressive beating could just ruin it. Like 556mm said, take your time, and work with it. Oh yeah, don't use acid.
        • 8233
        The best idea I heard, Pete,..
        Was to hang the whole bike from a ceiling joist by it.
        And then patiently abuse it.
        • wideglide38
          • Jul 2008
          • 656
          I find Kano' AeroKroil (the oil that creeps) works well with a couple of days of small applications.
          William Edwards, AMCA #10035
            50% Acetone and 50% ATF and you have Kroil at 1/10 the price.
              • 8233
              http://www.kanolabs.com
              I've still got a half-case of that, William!
              The valves went faulty and p'd customers off.
              And I only use it a couple drops at a time.
              But often.
                • 964
                Kroil and heat.Put a space heater in front of it.Impact taps with hammer.
                • 46EL
                  • Apr 2009
                  • 728
                  Before you go beating on anything or heating up your frame read Palmers restoration book. 1st edition page 67 first two paragraphs might help depending what your trouble is on seat posts that are stuck. if I remember correctly there is a reason they get stuck and they need to be rotated/turned one way or another if I remember correctly to release them. check it out.
                  • Flathead fathead
                    • Jun 2017
                    • 42
                    I've used Kroil for 40 plus years (not AeroKroil) and it's always worked for me. I learned about it from a very old retired H-D mechanic. Your problem might not be rust though, you might have a bent pogo.
                    • Dablaze
                      • Apr 2011
                      • 157
                      Could be worse than that, on my first ‘50 frame there was only about the top third of a pogo...however they cross drilled through the frame, spot welded the pogo into the seat tube and then cleaned and moulded the frame. Did a nice job, took me a while to realize it.
                      However, it’s much more likely to be rust. Can also be that someone rammed a pogo into a seat tube that had been “modified” to fit an ego or shovel.
                      See y’all at Wauseon, if my new heap makes it! (Orange square box Chevy, pretty beat to death)
                      Craig
                        • 6012
                        I agree, Bob; but I have to say that Kroil does smell better.
                          • 8233
                          And a bit safer around the torch, too, Folks.
                          • 55tmm
                            • Dec 2009
                            • 158
                            Here is what one of mine looked like after I got it out, water gets in there and they rust inside the frame, I had a couple like this and helped others, always the same. ( Rust )
                            • 55tmm
                              • Dec 2009
                              • 158
                              Another one, rusted in solid, slide hammer hooked to a chain hoist.
