Oversized rocker shafts
  • 1970 XLCH
    • Nov 2010
    • 177
    Does anyone know if anybody is making oversized rocker arm shafts for Shovelheads ( aprox .005 ) ? Thank you , Mike
  • 41craig
    • Nov 2010
    • 410
    Mike; I checked my sources and did not find o.s. shafts. Normally you replace and size new bushings in the rocker arms. The problem for a person doing their own work is the $ 172.75 dealer priced reamer.
    Craig
    • TomL
      • Jan 2018
      • 109
      Lots of Industrial Tool Suppliers with reamers and priced so a hobby shop can afford one, 25-35 dollar range but you may need a Bridgeport or Lathe to properly complete re bushing to size.
        • 8233
        Sorry to get out of my Zodiac, TomL!
        But reamers don't usually need a machine, if their cutting edge is over-length enough to pilot from both bearing surfaces.
        My hopes are somebody can link us to a source of such, even if semi-affordable, because I need just shy of a quarter-incher of four-inches or more,..
        seriously.
        Thanks for the hope!
        PS: There used to be a machine shop in the next town downroad (not even the "highway") that did such things for me perfectly. (*sigh*)
        • TomL
          • Jan 2018
          • 109
          Reamer
          • TomL
            • Jan 2018
            • 109
            This style needs to be "chucked" in a machine and is what I was referring to in sizing rocker arm bushings that have been replaced.
              • 8233
              Of course, TomL!
              I am suggesting that a reamer with a flute length longer than the rocker arm would make it much simpler.
              Then you wouldn't need to figure out how to fixture the arm;
              Just hold the reamer in a vise, and twist the arm on by hand.
              I always Sunnen-honed shovel bushings anyway, but they don't make a 1/4" mandrel long enough for carbs.
              So I must commission a long reamer that will align skewed bushing bores before I hone-finish.
              • TomL
                • Jan 2018
                • 109
                I see what are driving at, "simple" anyone can, who grasps basic machining, can make it happen. Ah the perfect world. I sure wished I hadda moved there when I was younger! :-)
