Tachometer part# 92051-65
  • ryan
    • Mar 2017
    • 610
    I have a complete tachometer correct for my 1969 flh, but I am hesitant putting on my bike because I have to drill through my headlight bucket. Any opinions and will it hurt or add value?
  • 1950Panhead
    • Jun 2010
    • 343
    No you don't.
    • ryan
      • Mar 2017
      • 610
      Boy I'm glad to see that, I sure heard wrong then. Is there a cable with a 90 degree bend that fits under the tach mounting bracket? The cable I have does not seem to fit, part# 92062-6SA.
      I have this bracket:
      https://www.ebay.com/itm/Vintage-Har...QAAOSwfiZca7CA
        • 4770
        How are you trying to mount it?
        • ryan
          • Mar 2017
          • 610
          I am bolting the bottom of the tach to the top of the bracket. The bracket then bolts to the handlebar clamp cover, but I have not drilled any holes yet. I ran the cable between the handlebar clamp and the nachelle headlight bucket.
            • 5946
            Where does this word nachelle come from? Harley-Davidson called it a housing.
              • 8225
              PickyPickyPicky, Chris!
              It's spelled 'nacelle'.
              My question is: What color are the indicator lights supposed to be on which side, and how many holes in each side?
              (For '65 ha ha..)
              PS: Thanks in advance as always...
              • ryan
                • Mar 2017
                • 610
                (For '65 ha ha..)
                I post with a kindle which has auto correct and changes the spelling of words it thinks should be there, hence nacelle to nachelle. Maybe the use of "nacelle" upsets the aircraft members. I just wanted to avoid the question of having the correct headlight assy.
                My 1969 FLH has a red light on the left and a green light on the right. My 77 FLH has two toggle switches on the right.
                  • 8225
                  Kindles don't sound friendly, Ryan!
                  Seems few nachels are poked the same.
                  A fellow who worked at the Factory in '65 told me that some of assembly was often left to the Dealer.
                  "As left the factory" requires a crate.
                  PS: Late edit..
                  My '65s have the square-brooched hole for the tach drive. I coulda had one more toy!
                  • ryan
                    • Mar 2017
                    • 610
                    Yes, the kindle is a pain sometimes.
                    I have distributor cable adapter 92097-65. My tach needs the aluminium glass ring replaced. I have one, but would rather send it out somewhere just in case of whatever.
                      • 4770
                      I used to drill my magneto shafts on my strokers, press in a chopped off speedo drive end, rob a drive unit off a BT or Sportster timer, drill the mag cap, and run H-D mechanical tachs right off the shaft end with a Sportster cable ( I ran the tach in the dash, no speedo). Worked great, but I used up a few of those tachs over the years. And I have no issues with the word "Nacelle", I own Pre-Unit Triumphs and other Brit nacelle wearing bikes.
                      • ryan
                        • Mar 2017
                        • 610
                        It looks like the cable should have a 90 degree bend at the tach end. I guess the cable could be wrong, but who knows.
                        • murph
                          1959 xlch
                          • Jun 2009
                          • 226
                          I don't see any part or number referring to any 90 degree bend in the parts book. Any that I have seen the nacelle was drilled so I'd be curious on this finding. Here is my 68 with a hole just big enough to fit the cable through in the nacelle.
                          1959 XLCH
                          • ryan
                            • Mar 2017
                            • 610
                            Hey thanks Murph for the confirmation! Great looking bike! I changed both my gauges to SW with bulbs. I have a temp gauge, but do not want to drill into the head. I suppose I could use an earth ground clamp.
                              • 5946
                              I have this Tach Drive if anybody needs one.
