Restoring a 1966 FL
  • Pete Engelman
    • Apr 2018
    • 147
    Restoring a 1966 FL
    Hi everybody. I recently purchased a 1966 Harley Davidson FL. I read that there were 2175 FL models built in 1966 and all were service bikes, police etc. There was an FLB (hand shifted 4 speed) and the FLFB (foot shifted 4 speed) Can anyone tell me how to determine which model I have and where I could get any restoration information. Thanks Pete:::::::;;;;;;;;
  • Lonnie
    • Feb 2002
    • 591
    Hi. First of all, not all 1966 FL's were service bikes or police or the like, though it is my understanding that most police bikes were ordered as FL's, but certainly not all. Regarding hand shift vs. foot shift, unless you have particular documentation on that specific motorcycle it is almost impossible to determine what it was originally if it has been modified. If you can back-track through the previous owners perhaps they can offer information or best of all photographs indicating its original appearance. I am not aware of any restoration guides on the early slabside shovelheads. The beauty of a '66 is that this is the first year for the frame mounted hand shift so it can be configured either way at this point. I've had a couple of '66's including one with the 3.5 gallon fuel tanks, these first year shovelheads turn out nice. Good luck with your restoration.
    Lonnie Campbell #9908
    South Cackalackey, U.S. of A.
    • vph-d
      • 1082
      Call the customer service department at the factory with your serial number. They'll supply a build date, and sometimes a little more info.
      VPH-D
      • flathead tom
        beepo
        • Sep 2008
        • 144
        on my 1966 fl police factory hanshift model on the title it says 66flb om my 1969 flh factory footsift on title it says model 69flhfb hope this clears things up for you !
        • Pete Engelman
          • Apr 2018
          • 147
          Thanks for your help Lonnie
          • Pete Engelman
            • Apr 2018
            • 147
            Thanks Tom It's a canadian bike so no title. It has a ratchet top 4 speed so this could mean it was a foot shift bike but who knows. There is a divot on the left frame down tube where a hand shifter could be installed with a set screw but it's anyone guess. It is a police special by the speedo. I even contacted HD Milwaukee and they had no info other than they could sell me the parts and service manual
            • vph-d
              • 1082
              Like I said, call the Customer Service Dept at the factory, they have provided for me info on all my modern bikes.
              VPH-D
              • Speeding Big Twin
                • Mar 2010
                • 430
                Pete, I agree with VPH-D; call H-D Customer Service. Some info from the 1960s is still available, including the build date and what model the bike began life as (footshift or handshift). AFAIK the phone number is still 414-343-4056. Tell them your serial number and belly numbers.
                How original is the bike? Depending on what’s happened over the years it may have three additional original component identifying numbers, sometimes called security codes or anti-theft numbers.
                The additional ID may be stamped on the left side of the frame steering head, outside the left fork stop on the lower triple clamp and on the front of the trans case on the R-H side just below where the lid attaches. The ID may consist of one capital letter followed by either three or four numbers but the characters are only about 1/8” tall. The three sets of ID will probably not match each other and even the letters may be different. For a 66 Shovel frame and lower triple clamp the letter may be D, E, F or G although some letters can also relate to some other years. For a 66 Shovel trans case the same four letters may apply but don’t be surprised if you find C instead. If all three sets of ID are original to the bike then H-D may be able to confirm them.
                Eric
                • Pete Engelman
                  • Apr 2018
                  • 147
                  Eric
                  Thank you Eric. The belly numbers on the cases match there is also the # 7 stamped on the rear engine mount of each engine case. I'll try and clean up these areas and look for additional numbers and I'll call the number you gave me. Thanks for the info.
                  Pete::::::::::;;;;;;;;;;;
                  • Speeding Big Twin
                    • Mar 2010
                    • 430
                    You’re welcome Pete. Over the years (1941-later) H-D used at least two types of 7 on top of the cases but for Shovelheads they are normally sans serif as per the example below.
                    Eric
                    • Pete Engelman
                      • Apr 2018
                      • 147
                      Thanks Erci
