67 Shovelhead Rear Brake
  • 67 Shovelhead Rear Brake
    Can someone tell me what type of washer is used on the outer block that the banjo bolt goes through to the wheel cylinder on the rear drum brake of a 67 Shovelhead? I used copper but it wanted to leak. The manual doesn't indicate.
    Thanks!
    There are (2) copper crush washers (p/n 41744-58) that goes (one each side) on the swivel fitting (p/n 41750-63) that the banjo bolt (p/n 41743-58) passes through.
    William Edwards, AMCA #10035
      Available at any good auto parts store. Grooved both sides. Easy to figure i.d and o.d.
      DrSprocket
