Guide 68 tailight
  • otis71
    • Jul 2015
    • 597
    Guide 68 tailight
    Pulled out my tailight stock for a 1969 FLH I’m restoring and I noticed a couple were Guide 55 and one was a guide 68 with the only external difference being the identifying stamping. Is the Guide 68 the correct one to use?
  • Omarttentmaker
    • Dec 2009
    • 318
    I believe the stamping on the body should have the 68 number on it, but the red lens for that year and later is tall, whereas the earlier red lens is flat.
    • otis71
      • Jul 2015
      • 597
      So the tailight body stamped Guide 68 is correct for a 1969?
      • cdndewey
        • Jan 2005
        • 438
        Yes it is correct. If you put them beside each other looking at the rear of them you will see a difference in them.
        • vph-d
          • 1088
          The bulb holder varies between the two lamps. Either one will bolt to the fender, but you want the one stamped 68.
          VPH-D
          • Sportster Jerry
            • Jul 2007
            • 165
            The Guide 68 is the correct shell for your 1969. I believe 1969 was the first year it was used.
            As stated above, the taillight socket mounts differently inside the shell. You should also have the "projection" clear outlook lens that extends above the shell, and the red tail light lens that sticks out beyond the shell in the back to make room for the bulb in it's new mounting position.
            • BigLakeBob
              • 2766
              Good additional points to mention. Thanks.
              Bob Rice #6738
                • 2018
                Federal law was changed and required that brake and tail lights be visible from the side so the -68 tail light has lenses that protrude slightly from the housing.
                Jerry
                • Sportster Jerry
                  • Jul 2007
                  • 165
                  Jerry
                  The red tail light lens is actually a -69 part (68090-69). The parts manual shows the entire assembly (including the Guide 68 shell) to be a 1969 model year change, and I believe this to be true. I have a very late production original paint 1968 XLCH and it still has the Guide 55 tail light assembly. As Jerry W. mentioned above, it was all part of the 1969 federal law change that required the side reflectors to be added as well.
                  • dommi7
                    • Jul 2001
                    • 109
                    My 69 has the -55 light. I don't believe the updated part was used throughout the model year.
                    It would be nice to hear from the owners of original paint machines
                    Ralph
                      • 2018
                      I suppose anything is possible but I have been around a lot of 1969 FL's and XL's and every one of them had the -68 taillight assembly. I believe the new law went into effect in 1969 but there is such a thing being effect January 1 vs model year 1969 which possibly excluded early production machines. Somewhere I have 1969 Sales Literature and it would be interesting to see that. Jerry
                        • 4784
                        See #2..
                          • 2018
                          Yep This is the flyer that I have too - just never got around to locating it. Jerry
                          Originally posted by Rubone View Post
                          See #2..
                          • dommi7
                            • Jul 2001
                            • 109
                            Pretty hard to dispute that! Thanks for posting.
                            Though I do note they mention improving on the "already Superior Glide braking"
                            Ralph
                            • vph-d
                              • 1088
                              73 is another early/late model year. The early bikes [up thru Dec 31?] had the -69 tail lights and no turn signals
                              VPH-D
