"69"shovel
  • Colonel-46-El
    • Oct 2014
    • 42
    "69"shovel
    well here I am agin ,can somebody tell me what casting date's would be on late "69"shovelhead,,please,an thank you cylinder heads
  • Steve Little
    • Apr 2008
    • 915
    You will need a torch...The casting date is sitting on the top radial fin behind the pushrods.
    Steve Little
    Upper Yarra Valley. Victoria.
    Australia.
    AMCA member 1950
      • 8233
      Better remind Folks, Steve!
      "Torch" should be for American parlance, a "flashlight".
      Americans can take things quite literal.
      • Steve Little
        • Apr 2008
        • 915
        Thanks Tom.
        Colonel...don't burn that poor old Trouble head to the ground.
        If you use a "flashlight" you might be able to see the cast date in behind the push rod tubes. Its a cow of a place to see but it should be there.
        Here is an example...even though its a later head. All heads from 1966 had the cast date, but at some stage I think they stamped the date in between the opening of the rocker box....maybe the 80's
        Steve Little
        Australia.
        AMCA member 1950
        • Colonel-46-El
          • Oct 2014
          • 42
          thank you all for the help
          • Colonel-46-El
            • Oct 2014
            • 42
            "69"
            the HUNT is on....
            • painterdale
              • Oct 2013
              • 423
              Whatcha lookin' for, Colonel? Maybe someone here can help.
              Dale
