Help with 74 FXE Wiring
  • eddiepanhead
    • Jan 2007
    • 171
    Would anyone happen to have a photo(s) of the wiring that resides under the headlight visor?
    I have a mostly stock 74 FXE that needed a new harness, everything work great after installation, just need guidance on the routing of
    the handlebar harnesses and how it all tucks in and around the headlight.
    Where does the signal flasher live under there? Does it attach to anything?
    As always, thanks for your help.
    Ed
  • motorhead1
    • Dec 2006
    • 171
    There should be a clip rivited to the inside of the headlamp bucket just like the ones on the rear fender for the circuit breakers. Although the flasher is round, it was just pushed right in the clip.
    Ride 'em. Don't hide 'em.
    Dan #6938 FUBO
