AGM Replacement to 66007-84 Battery
  • wideglide38
    • Jul 2008
    • 656
    Has anyone found a suitable replacement AGM (Absorbed Glass Mat or Sealed type) battery for H-D p/n 66007-84 (12V 32Ahr) battery? I'd like to get away from the dry cell battery.
    William
    William Edwards, AMCA #10035
  • 55tmm
    • Dec 2009
    • 158
    I just ordered one last night from Batterystuff.com
    It is AGM, going to give it a try? https://www.batterystuff.com/images/...Battery_lg.jpg
    • wideglide38
      • Jul 2008
      • 656
      Thanks 55tmm, Let me know how it fits in the bike and any cover issues. Thanks, William
      • 55tmm
        • Dec 2009
        • 158
        I will let you know, should have it by the end of the week.
        • wideglide38
          • Jul 2008
          • 656
          Thanks. I found the OEM web link which provides more specs than the batterystuff.com website. Only real difference I see the Amp Hour rating. (OEM @ 32Ah and Scorpion @ 28Ah).
          We are a lay ministry training and project management group. Christian charity.
          • 55tmm
            • Dec 2009
            • 158
            William,
            Battery came today, exactly the same size as OEM, fit in perfect and the cover goes on with no issues.
            Now need to run it and see how it works out, no more checking fluid level...
            • wideglide38
              • Jul 2008
              • 656
              Thanks 55tmm,
              I appreciate the follow-up. I will probably order one.
              William
              • Lyle Manheimer
                • Mar 2008
                • 193
                Industry standard for battery ratings is AH or Ampere Hours. A 32 AH battery is supposed to sustain a 32 amp discharge rate for 1 hour and maintain a terminal voltage of 12 volts. A 28 AH battery is supposed to sustain a 28 amp discharge rate for 1 hour and maintain a terminal voltage of 12 volts. If the motorcycle came with a 32 AH battery from the factory it is best to replace it with one of the same AH rating. The charging system is designed for a 32 AH battery including the alternator/generator and voltage regulator.
                You might get away with a lower AH rated battery for the motorcycle, however with the charging rate of the motorcycle being higher it could very well have an effect on the longevity of the battery or worse. I would certainly keep and eye on the sealed battery and watch for signs of overcharging most obvious sign would be a bulging of the case.
