Oil spots
  • JosephJoe
    • Sep 2011
    • 36
    Oil spots
    Gentlemen,
    After starting my FLH ' 70, I hold my hand just behind the exhaust and noticed there came out little oil spots.
    Do I have to worry about that?
    Thanks in advance,
    Joe
    • 8233
    Joe!
    Late models aren't my specialty, but since it is similar to my '65s, I must ask:
    Had the machine been sitting for a while?
    Oil has a habit of draining from the tank into the motor, and making a mess when started.
    With the factory design, it can clean itself up in a matter of a few dozen miles. If you have alterations like seals for a belt drive, etc., it can be a headache.
    Let us know more...
    • JosephJoe
      • Sep 2011
      • 36
      Cotten!
      I ride my bike on regular base, once a week.
      The spost are very fine, like pinholes.
      Joe
        • 8233
        Joe!
        Golly, if it isn't sumping, its 'sumpin else', I guess.
        What do your plugs look like?
        • JosephJoe
          • Sep 2011
          • 36
          Thanks for your reaction Cotten,
          The plugs look pretty good, coffee brown.
          Joe
            • 4784
            Joe,
            Is there anyplace any oil leaks on a pipe joint or into a port? Fine oil mist can be carried in the exhaust that originates from other than within the engine.
            • JosephJoe
              • Sep 2011
              • 36
              Hi Robbie!
              I can't think of anything.
              Could it be a leak of the valve guides?
              Joe
                • 4784
                Joe,
                If the guides allow oil into the exhaust port it could blow a bit out upon initial start up, but as it comes up to temperature it would normally vaporize and perhaps puff a bit of smoke. Does it continue to do it after riding for a while or only at first start?
                • JosephJoe
                  • Sep 2011
                  • 36
                  Robbie,
                  Indeed, only at first start when the engine is cold.
                  Joe
                    • 8233
                    Joe!
                    Another common spot for oil to enter the combustion chamber is at the headgasket around the drain holes from the heads.
                    Just like intake guides and the like, only a tear-down would tell.
                    • JosephJoe
                      • Sep 2011
                      • 36
                      Gentlemen,
                      Thanks you for sharing your knowledge.
                      Joe
