Weird noise from starter
  • JosephJoe
    • Sep 2011
    • 36
    Gentlemen,
    Sometimes when I push the electric starter of my 1970 FLH Shovelhead it makes a loud banging noise, like if you hit with a hammer a piece of metal.
    When I push again it starts normal without the noise.
    It will do this approximately once out of every ten starts.
    Does anybody know what could be causing this?
    Thanks in advance,
    Joe
    • 4784
    Check your auto advance unit. If it is sticking the starter is up against a brick wall....
    • vph-d
      • 1088
      As Rubone stated, check your advance weights, you might find them stuck fully advanced, which kills the starter bendix.
      VPH-D
      • billpedalino
        • Mar 2005
        • 1096
        You might also check the Bendix Drive as well.
        Bill Pedalino
        Huntington, New York
        AMCA 6755
        • flathead tom
          beepo
          • Sep 2008
          • 144
          missing teeth on ring gear on clutch hub
          Originally posted by JosephJoe View Post
          Gentlemen,
          Thanks in advance,
          Joe
          mabe missing teeth on clutch drum !!????
          • jim d
            • Sep 2010
            • 281
            Wornout Bendix drive if you ever take one apart you will fine some small springs inside sometimes they are smashed or just weak, it will work fine in your hand but not under a load. If the timing is advanced to far or not returning it will make it kick back smashing those little springs. Or sometimes the springs just become too weak to hold the drive inside the Bendix.
            Jim D.
            Jim D
            • JosephJoe
              • Sep 2011
              • 36
              Gentlemen,
              Thank you all for your expert intervision.
              We have replaced the auto advance unit, and up to now the bike starts as it should be.
              Joe
