Internal throttle
  • JosephJoe
    • Sep 2011
    • 36
    Internal throttle
    Gentlemen,
    On my 1970 FlH Shovelhead I use a S&S carburetor, but I want to keep the internal throttle.
    What are the options?
    Joe
  • BigLakeBob
    • 2766
    You don't say what style S&S. I ran both an L series and a B series on my '69FL. No issues, you already have a pull type throttle, the cable rests in the boss on the carb. You may need to change cable lengths and routing. The air cleaner clears 5 gal tanks on both these carbs. I made customs footboard extensions so it was more comfortable and not a bent leg while riding. I am not familiar with anything newer than the B series.
    Bob Rice #6738
    • vph-d
      • 1076
      I think a 70 has the push throttle. You will need a 56220-58 spiral to convert to a pull throttle.
      VPH-D
      • JosephJoe
        • Sep 2011
        • 36
        Hi VPH-D,
        Thank you for your respons.
        Do I need a wire- or solid cable?
        Or anything else like a "conversion kit"?
        Joe
        • BigLakeBob
          • 2766
          Sorry, should have looked, agree-push is stock.
          Bob Rice #6738
          • vph-d
            • 1076
            The only conversion kit I can think of is to use a post 74 external cable set up. Your 70 has an internal solid wire throttle cable. You would use the -58 spiral to convert your stock throttle to pull open an S&S carb. I have run the L, B, and the E series of carbs myself, but never with a stock throttle. The E carb is the best by far, especially in the bottom end.
            VPH-D
            • sieber60
              • Jul 2014
              • 81
              Where can a person get the part to convert.
              • sieber60
                • Jul 2014
                • 81
                • vph-d
                  • 1076
                  Contact Chuck at Kick Start in Michigan, I believe has has the correct spiral. Also, I think the part was used on lightweights, so you might try Hummer suppliers. Don't get confused and buy the -47 spiral, it won't fit your bars.
                  VPH-D
                  • sieber60
                    • Jul 2014
                    • 81
                    VPH-D
                    Thanks for the info, I will contact him.
                    • shovel_head_fred
                      • Mar 2010
                      • 9
                      I'm running an S&S B on my '68 using the stock wire cable and throttle. I added an L shaped bracket that holds the cable in position. This bolts to the manifold and PUSHES the throttle plate open, instead of the usual pull. The bracket has a hold tapped for a 8 or 10-32 screw that claps the cable to the bracket and allows for minor adjustment. Cable comes around left side of frame. Seems to work fine, so far.
                      Hope that helps.
                      Fred
                      • Gonzo47
                        • Oct 2014
                        • 5
                        I have ran an S&S "G" and a "B" as well as my current Mikuni with an early style internal throttle.
                        I replaced the cable housing with a generic metal housing from a lawn mower shop as you can get it pretty long. (I run apes) then use 4' sections of shrink tubing and overlap each section by about an inch. You can use two layers for extra protection. For the actual cable. I used 1/16th inch diameter cable from home depot and tin the ends with solder. For the carburator end, I use a barrel end with a set screw available at Napa. Be sure to lube the housing with graphite or silicone prior to inserting the cable.
                        I may have some pictures if you like.
                        Good Luck,
                        Gonzo
                        • Gonzo47
                          • Oct 2014
                          • 5
                          BTW,.... I also use a internal on the left side to advance and retard the timing. There are two different internal assemblies. One will push one will pull.
                          Gonzo
