1966 FLH carburetor DC-7
  • chgofire5sqd
    • Feb 2012
    • 24
    I was doing some routine maintenance and cleaning on my DC-7 carburetor and I noticed when I removed the air cleaner and backing plate. The little spring for the choke lever that is set into the small hole on the back plate was by itself. Is there something missing or does the spring itself ride against the choke lever notches. I looked up this question in Clymer's shovelhead book, but he did not have a answer or exploded picture that part I could reference. If there is a piece missing can you send a picture of it or describe it. Thanks as always for the info.
    • 4776
    There should be a small ball bearing that rides in the notches and is tensioned by the spring.
    And I believe most Clymers manuals work best as bird cage lining...
    • chgofire5sqd
      • Feb 2012
      • 24
      Thanks for the fast reply. looks like that came out at some time. Love the comment on Clymers. Its worked for me on projects, but always open for suggestions for what shop manual is best on my 1966. Thanks again Rubone
      • flathead tom
        beepo
        • Sep 2008
        • 144
        bird cage lining
        toylet papper in the outhouse is also good for the CLYMERS MANUAL
        • murph
          1959 xlch
          • Jun 2009
          • 226
          Old Dude sells the springs and balls, buy a few to keep around. Grease both during assembly makes it easier sticking things together.
          1959 XLCH
          • Rollo
            • Nov 2008
            • 599
            Get yourself a factory service manual and parts manual, even if they are reprints. That will go a long way to helping you work on things.
            Tom (Rollo) Hardy
            AMCA # 12766
